yeh your right, cant wait for my next holiday so i can post on the internet all the way though it will be like totally so awesome.
no nerve brah.
i seen you, i know why your single ain't your fault man pretty sure they didn't drop you intentionally.
Thats hilarious shit right there... you sound emotionally disturbed by what i have said lol
Lets talk it out brah, i can be very accommodating to people with depressive/demoralized feelings, if you can stealthily avoid any ridicule from me lol
In for shisha. There's a place in St Kilda that's got a private courtyard and some good shisha. Otherwise there's always that The land of goat sphincter rings joint on Lygon st.
Erm... it's a Lebo/Arab joint.
That shisha thing isnt a The land of goat sphincter rings custom
lol i don't give two farks about ya, like seriously i wouldn't piss on ya if you were on fire.
If you're spending money on your girl.. you're doing something wrong. Get a independent women who can take care of her self.
you spend hundreds/thousands on your car but wont spend money on your girl?
yes you get an independent women who can take care of herself when she's by herself, you're a man for a reason...
another mrs? You're moving through em lol
asian women dig the muztek
Pouring down here. Clouds so dark.
fell asleep when i got home after work and woke up to the heaviest/loudest rain was f**ked
hahah
this
the owner seemed The land of goat sphincter rings to me?
call a turk an arab, and vice versa. sit back and watch the lulz
ok gaiz, saturday or friday?
bring your wimmens so they can have a bitch fit etc together
