F**kn lost my dog this morning.
Let him outside for 3 mins to take a piss and his done a runner, because our fence hasn't finished his found a small gap in the fence.
Dog is tagged and has our phone number on it but no one has called or turned him in yet :(
It's a new house so don't think he'll find his way back home...
Feel really bad becuase its my missus dog shes had for 11 years :(
Tony, that sucks hope you find the dog.
Drive and walk around for 3 hours trying to find dog, and making phone calls to council and RSPCA all day no luck.
Then gf's sister comes over and looks for 5 mins and find him.... What luck
Huge relief
Btw cheers for the drive last night!
R33 stockies do not fit on r34s...
No?
Huge relief
Does your gf know the dog went running?
And that's good to hear that you've found him.
Also no worries and cheers for the drive, you need real seats!
hmmm
Surely there's an app for it somewhere. Does that feature have a name or something?
hold centre button and press the off button... it is then saved as a screen capture in a dedicated gallery
also galaxy s2 pwns ipod
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
