Maybe get your cousin to buy the car, own it for a year then send it back.... Would be the best way to do it.
Hrmm now you got me thinking. Will check out the UK version of carsales for fun at lunch time.
Import a R35 for track purposes... now that's worth something to think about.
From the US? There's something better there such as Corvette Zr1, Camaro zl1, Mustang etc but they're compliable, only personal import if you can't comply here in Australia, otherwise its waste if time
UK ain't all it's cracked up to be. Their petrol is ridiculously expensive and enjoy your rego on anything with more than a 2 litre engine...then there's the ugly, fat and depressing lifestyle/weather.
Import from the states = $30k to do a proper conversion from LHD.
It's not as easy as it sounds; for every loophole you can think of around paying high prices for cars locally, it's all been thought of / done before. This is reflected in the prices of our local second hand market and the overseas import markets. It's the reason why you can go to Japan and buy a 1998 RX7 for $9k, whilst a 1999 RX7 will cost you $18k - the latter can be imported to Oz.
Buy a delivery km Mustang in Australia for ~70k-80k, the same car will cost you 35-40k in the US...add your RHD conversion, shipping etc. You might come out 5k better off after the hassle and risk involved in importing yourself.
Personal import is probably the only thing worth considering to save money, if you can pull it off...
I lol every time i see a Mustang or a Camaro... Apart from the fact that they aren't very good cars
Die in a fire!
Actually... Now i have me thinking, My sister is there on a two year Visa... She won't drive so would just need to store it for a year :3 hrmmmmmm
Then there's the ugly, fat and depressing lifestyle/weather.
Die in a fire!
Hey! I meant the new ones of course! I love the old muscles, and you don't need to convert them so of course it's worth while. Just not worth importing a car for $110k when it's ghey, they're just an American Commodore. C-o-m-m-o-n. As for the old schoolies they are super cheap in the US as well and I would definitely approve importing one.
Also the UK might not be that fun to drive in, tolls into the city are disastrous as well. It's more about popping over to France, down through Andorra to Spain or Switzerland to Italia. Mmmmmm Alps. Nom nom nom.
Edited by Cha_Chaos
So a quick look on Piston heads shows:
08 M3 ~ 30K
04 Gallardo ~65K
07 911 Turbo ~ 50K
Today exchange rate = 0.63
So for say the 2007 911 Turbo ~$80,000.
I have no idea on the costs and hassles of importing from the UK but just putting it out there....
Strong Aware.
Impressed.
Baffled.
You have to use the car while you're there
It would be registered but not driven... My sister doesn't drive and who wants to when you have the tube. Would be treated like a standard car except it wouldn't increas in km's.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
