Maybe get your cousin to buy the car, own it for a year then send it back.... Would be the best way to do it.
Hrmm now you got me thinking. Will check out the UK version of carsales for fun at lunch time.
Import a R35 for track purposes... now that's worth something to think about.
From the US? There's something better there such as Corvette Zr1, Camaro zl1, Mustang etc but they're compliable, only personal import if you can't comply here in Australia, otherwise its waste if time
UK ain't all it's cracked up to be. Their petrol is ridiculously expensive and enjoy your rego on anything with more than a 2 litre engine...then there's the ugly, fat and depressing lifestyle/weather.
Import from the states = $30k to do a proper conversion from LHD.
It's not as easy as it sounds; for every loophole you can think of around paying high prices for cars locally, it's all been thought of / done before. This is reflected in the prices of our local second hand market and the overseas import markets. It's the reason why you can go to Japan and buy a 1998 RX7 for $9k, whilst a 1999 RX7 will cost you $18k - the latter can be imported to Oz.
Buy a delivery km Mustang in Australia for ~70k-80k, the same car will cost you 35-40k in the US...add your RHD conversion, shipping etc. You might come out 5k better off after the hassle and risk involved in importing yourself.
Personal import is probably the only thing worth considering to save money, if you can pull it off...
I lol every time i see a Mustang or a Camaro... Apart from the fact that they aren't very good cars
Die in a fire!
Actually... Now i have me thinking, My sister is there on a two year Visa... She won't drive so would just need to store it for a year :3 hrmmmmmm
Then there's the ugly, fat and depressing lifestyle/weather.
Die in a fire!
Hey! I meant the new ones of course! I love the old muscles, and you don't need to convert them so of course it's worth while. Just not worth importing a car for $110k when it's ghey, they're just an American Commodore. C-o-m-m-o-n. As for the old schoolies they are super cheap in the US as well and I would definitely approve importing one.
Also the UK might not be that fun to drive in, tolls into the city are disastrous as well. It's more about popping over to France, down through Andorra to Spain or Switzerland to Italia. Mmmmmm Alps. Nom nom nom.
Edited by Cha_Chaos
So a quick look on Piston heads shows:
08 M3 ~ 30K
04 Gallardo ~65K
07 911 Turbo ~ 50K
Today exchange rate = 0.63
So for say the 2007 911 Turbo ~$80,000.
I have no idea on the costs and hassles of importing from the UK but just putting it out there....
Strong Aware.
Impressed.
Baffled.
You have to use the car while you're there
It would be registered but not driven... My sister doesn't drive and who wants to when you have the tube. Would be treated like a standard car except it wouldn't increas in km's.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
