Hrmm wanna sell the headlight spacers? That's the part I need lol
Nope :)
Wheel tech do really good work they in dandenong
I was not impressed with the work performed.
I've gotta get my wheel redone as a result
Always Powdercoating off Gatwick Rd in Bayswater...got some scratched up S15 alloys coated there and they looked factory brand new. Was about $45 a wheel? You can't always get the coats perfect / completely scratch-free, but you'd struggle to tell unless you examined up close.
I don't really need powder coating done I really want the outer lip polished properly. The car used to sit in one spot for months and you can see the corrosion from where the rain would sip and drip out. If someone wants to polish for me and give it a shit I'll be happy tried autosol with a drill but didn't really do much
Nerds are underrated. I'd stickerbomb the car with pokemons and drive around with an Ash baseball cap on, shouting out sleazy puns at P platers in Lancers.
Rofl.
There's a car with the plates EDBTZ,
Means My hand is in my ass. Lol
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
