Interesting seen a few mates wheels done by them came up really awesome
Yeah but I am very fussy, and will pay for a perfect job. Also seen bad work from the other place mentioned.
Problem is such places pricing is pretty cheap, so i think that is why they can be hit/miss at times.
yeh i dont know what it costs i was only commenting based on the work i've seen myself but like you said every place serves up good and bad work at times unfortunately just gotta hope its good when its your own car :laugh:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
