Love the rain! Gutters are f**ked and roof is leaking water into house but still pretty great.
it takes a fair bit more than words on the internet to piss me off :) btw, you're only bottling it up inside. you should let it out more often ;)
Is that an invitation? :P Just a bit of a girl I guess :glare:
I let it out when I ride at the Island or Sydney and I can scream in my helmet at the top of my lungs <3 Nothing takes away your problems more than a massive mono or sliding around a corner on your limit. Only one more week then I'm back :worship: Urgh. Withdrawals.
Back street boys?
That was actually one of the songs played lol.
I did Club Can't Handle Me by Flo Rida and it was interesting. So apologies to whoever liked that song before I spat on it.
Anyone on here using plazmaman products? Had a mate running a fmic on his xr6t and couldn't speak any higher of it. Definetly thinking of saving for a few months and getting a fmic with their plenum.
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
