Nice try Flynn your not even worth the effort it's clear to see whose a shit talking child
Posting pics like seriously buddy? U and ya fat missus barely fit in a profile pic together Bahahaha
And seriously dude I'm thinking u gotta gayboy crush or something like WTF u looking at photos of another bloke that's queer
Stop talking sh*t barbs.
In a 5min dig around the net, it's painfully obvious you are just a troll, and you've been doing this for years and years on various other forums as well.
Giving their Admin the shits, the same as you give us the shits. Making new accounts, posting the turkey dribble yadda yadda.
Give it a rest already, the internet has had enough.
One of your members is clearly violating forums rules with personal attacks, resorting to immature behavior due to lack of intelligence to make a formal argument, making statements in complete ignorance, yet.. you blame me for it? Who started the petty name callings? When he's place on a wall of shame, he cries foul. Is there any justice in this world?
I havn't doing this anything for years. Was a member of another chan4 like forum where anything went, making it one of the perks of the forum but the admin tends guess who the culprit is every one uses proxies and lists member names after another, taking a wild guess.
FYI, I don't have a mrs and no that person you're speaking of is not fat either..
WIIIINNNNNEEERRR
I'm trying to find a krav maga place that's a bit more local to me...nearest one is 25 minutes away and that's pretty cbf on a weeknight. Gotta travel for quality though sometimes...
Eastern suburbs? There's one in ringwood and chadstone that I know of
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
