Nice try Flynn your not even worth the effort it's clear to see whose a shit talking child
Posting pics like seriously buddy? U and ya fat missus barely fit in a profile pic together Bahahaha
And seriously dude I'm thinking u gotta gayboy crush or something like WTF u looking at photos of another bloke that's queer
Stop talking sh*t barbs.
In a 5min dig around the net, it's painfully obvious you are just a troll, and you've been doing this for years and years on various other forums as well.
Giving their Admin the shits, the same as you give us the shits. Making new accounts, posting the turkey dribble yadda yadda.
Give it a rest already, the internet has had enough.
One of your members is clearly violating forums rules with personal attacks, resorting to immature behavior due to lack of intelligence to make a formal argument, making statements in complete ignorance, yet.. you blame me for it? Who started the petty name callings? When he's place on a wall of shame, he cries foul. Is there any justice in this world?
I havn't doing this anything for years. Was a member of another chan4 like forum where anything went, making it one of the perks of the forum but the admin tends guess who the culprit is every one uses proxies and lists member names after another, taking a wild guess.
FYI, I don't have a mrs and no that person you're speaking of is not fat either..
WIIIINNNNNEEERRR
I'm trying to find a krav maga place that's a bit more local to me...nearest one is 25 minutes away and that's pretty cbf on a weeknight. Gotta travel for quality though sometimes...
Eastern suburbs? There's one in ringwood and chadstone that I know of
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
