Nah, it looks tough :P
On EMOs, yes but on Moh's 'special' car - nah.
Moh did the right thing by painting it matt black, speaking of painting the calipers, I need to do mine...
FYI stay away from the Kinglake/Toolangi & GOR area's - ANY time of night/day.
There is a big Police Operation going on over the next 2 months, all hours of the day/night.
Main aim is to catch the late-night runs though I've been informed ;)
You've been warned.
thank god they aren't trying to catch criminals
A motorbike went past on the opposite side of the ring rd, he was hammering and the thing literally sounded like a f**kin f1 car.
Must find out what kind of bike it was and buy one
any of your typical high performance road bikes really
R1, GSX1000 etc.
Any of them with exhausts/tune/cams scream like hell itself. Awesome :)
It was either that or after coming back to work after a 3 week holiday over the Xmas break.
So thought there's no point coming back to work and then going home :/
The one you extended her probation?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
