Didn't see turbos in the mods list, seems odd to run standard turbos after spending that much on the engine..
Any idea where it was built?
he probably ran out of patience and time haha. I do remember him mentioning new turbo's but never got a boost controller
Was rebuilt by ReCustoms
Ah yeah now I remember. It was sitting at RE for a very long time. It was there when mine went in for the build and still in the back corner when I left with mine
haha he made sure it was built right and didnt rush them. So it sat around most of the time and still does after the rebuild.
I want a r32 gtr now... haha
Surely you guys remember 386s before Celerons...I'm not the oldest here! 25mhz and 33mhz on turbo mode, 8mb (upgraded to!), 420mb hard drive...CD ROM with Sound Blaster!
I loved the turbo button. My first real computer of my own though was a Celeron 133mhz. Then I built computers for a number of years and moderated a huge AMD forum.
True story lol
Sounds alright, might have to head to the sticks for a test drive
That blue GTR is a lot of car for 27k.. much prefer to buy that than a stock 32 GTR. Duno how my mate managed to sell his stocker for 20k.. dash bubble and all :P
If i were buying again I'd deff get a modded one straight up
True story lol
Lol the turbo button... with it on the pc runs at normal speed, and off makes it run at half speed
Ron's GTR had pair of GT-SS in 2.8, now, it has pair of -5s, Nismo AFM and large-ish injectors and a re-tune by Sabbadin from memory.
I know cos he sold the GT-SS to me last year when I'd killed my standard turbos.
And $24k, f**king hell!
Depends on budget Dezz.
I know a very very clean 32 that's in the 30k region.
In the same league as this car. Both the above, and below, are Racepace built with perfecto bodywork
www.skylinesaustralia.com/forums/topic/386095-r32-gtr-silver-immaculate/
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
