Hamish is just a jealous turd imo
TS50 love
hmm noticed how none of your AU pics showed the horrid front end, no matter how awesome the tickford engine is and how much panache the 'new' bodykit gives the car it still suffers from the blight of a down sydnrome face...
:pirate:
Depends on budget Dezz.
I know a very very clean 32 that's in the 30k region.
In the same league as this car. Both the above, and below, are Racepace built with perfecto bodywork
www.skylinesaustralia.com/forums/topic/386095-r32-gtr-silver-immaculate/
Probably a bit over the top, price is outside of the budget as well...
It's for Sandra so even Ron's would be overkill, but if it can be had at the right price it'd be worth it, having been rebuilt etc.
Wouldn't really need anything spent on it apart from wheels
yeah no.... I already have a care with more power and less weight that can take corners.
Wouldnt mind having both tho...
Also, for the good of vic wl... Pls neck yourself
Nice 32 but i still wouldnt pay 30k for it :\ someone will sooner or later
It's worth 30k when flogged out, body terrible R32 GTR's sell in the 15-18k region. Clear R32 GTR's are just impossible to find at a cheap price. Most have had big hits, dodgy repairs etc.
And "built" GTRs with average bodies get 25k.
You get brakes, motor, supsension and a perfect body/wheels.
Anyone that buys a "cheap" 18-24k R32 GTR - IMO will end up spending another 6k on it anyway just to start off.
Might as well get one ready to go and pay a tad more. Save HEAPS more in the longer term.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
