Still not 160kph. Lol. With every action there is an equal opposite reaction. Whether the rock was standstill mid or or moving at you at 80kph, same force exerted/made >:|
I dont know, i think so. Haha. meh
Rock relative to the car would have been travelling at 160km/h...
yeh pretty sure it wasnt a 160km impact but whatever you got a dint spose thats the point.
if the rock is travelling towards me at 80km/h and im travelling at 80km/h towards it, then I am covering the same distance & relative speed as if the rock was stationary and I was traveling towards it at 160km/h.
If you want to get complex, the rock would have come off the car and lost speed on its journey towards my bonnet, so it wouldnt have been 80km/h but somewhere around there..
Point is i got a paint chip :angry:
Careful Grant with your 'researching' may not have been that many cops there that night as there normally is
Thought so, cos I was able to sail thru chapel st with minimal fuss.
FYP brah
LOL, how can I get defected again if I haven't been defected before?
Unless you meant something else.
