how easy is it to terminate a Cat5e cable? there is one hanging out of the wall plate behind the home theater and i wanna hook it up to my media center. the other end is hopefully hooked up to the wall socket next to my new gigabit router. no way to test it atm
Juliette should know I imagine
Front up to the doors yes, assuming you're talking about the 2-door since 4-door VZR's aren't eligible for import. Some interior parts are also interchangeable, some parts are different.
