Sounds like coilpacks or spark plug - a cylinder or two isn't firing. Unburnt fuel going through the hot headers or turbo(?) is what's making the cat glow.
If it does it at idle, you can diagnose by running engine with bonnet open and pulling/replacing each coilpack individually until you find the one that makes no difference to the engine sound. Then when you find the faulty cylinder, swap it's coil pack to another cylinder and see if the problem moves to the new cylinder. If it does, then coilpack. If it doesn't, then loom or spark plug in the original cylinder will most likely be it.
twas indeed a broken coilpack :)
funny, i had just finished making up the carsales ad for it when i went out and noticed it.
could be a sign? :closedeyes:
Good stuff^ could have been much worse. Could have been a sign that you're meant to keep it but most people take a car falling apart as a sign not to lol.
Have you decided who will do mechanical and tune brah?
I'll do the mechanical, not sure where to get it tuned yet. Recommendations?
Car will be driveable off boost with the high flow fitted...might leave standard injectors / ECU in there and baby it to the tuner. Tao did recommend Trent cause of his familiarity to the turbos, said it would be easy to tune off previous maps rather than start from scratch.
Power fc Birds? If so you can change settings to suit bigger injectors/afm quite easily. Then just stay off boost on your way to the tuner
Forgot about this, never used a PFC before but if it's that easy I'll look it up / get you to show me. I know there's a reset which defaults it to a really conservative "limp mode" allowing you to baby it to a tune.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
