Spent the night at the intercontinental Rialto, birthday present from the mrs. Fkin love staying in hotels, if I was rich I could just live in em, no worries, everything done for u etc.
The 458 out the front was porno
Very big turnout last night.
Anyone go on the actual cruise? I just went to go eat after.
Very late departure time and looked like a 4 hour cruise route.
yes definately.. stayed towards the front so wouldn't get lost with idiots this time haha :)
Not sure where we were exactly, but we seemed to lose half of them at one point, then Neil/Aaron/few others left and rest of us ended up in Yarra Glen, Ash turned up somehow? Then headed back towards Ringwood and went for 24hr pancakes and photos. Yay for dinner finally lol
yeh when people decided to overtake others while going through the mountain, i decided it was time to leave..
