This gtr has changed owners a lot...
I think I remembered looking at this exact 32 couple of years ago for lot less than 15k.
2am ish.. I kinda cock blocked a couple that may have been doing it at the mount dande carpark. Thought they were with us and walked around the back and go "why the f**k are you sleeping get the f**k up" and a mates like they aren't with us. Lolz were had
