There's an LFA at Blackburn Lexus.
Accidently drove past it and was like wtf. Don't think there would be many in Australia.
Yep, in white.
yeah i saw that driving past yesterday actually - looks amazing!
Why lol they are an incredible car? Lambo aventador is same? Let's face it if u got 700k to spend it's not ur only car and ya probably buying it cos u can
Pretty sure LFA stands for looks Fkn awesome! Hahah
Leigh I'm gonna be at jdmst meet! Bring the fpv down!
Reasons to buy an LFA:
- Demonstrate your ability to spend 700k
- With the price tag comes the unique factor
- You prefer the look over any other supercar
- You already own every other supercar
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
