Why lol they are an incredible car? Lambo aventador is same? Let's face it if u got 700k to spend it's not ur only car and ya probably buying it cos u can
Pretty sure LFA stands for looks Fkn awesome! Hahah
Leigh I'm gonna be at jdmst meet! Bring the fpv down!
I did but you left too early brah
and this proves why supercar manufacturers can charge what they do... with the exception of alex you are all looking at the badge before the car.
Bleh, I'm in favour of the LFA too, I listed reasons why the LFA will be irrelevant to most people here and why most would pick a Ferrari etc over one, number one being most people here don't have a spare 700k lying around nor have they "been and done" the other supercars. There are better performing supercars for the money, but no one's buying the LFA because they want to beat an R35 around the track with it.
Well, case in point, the last 3 pages have been about the LFA from a single sighting...if someone posted that they saw a 599 GTO it might have been talked about for 2-3 posts, if that. That's the uniquity that makes it worth buying IMO, regardless of how good it is. And it's not like you're getting a Corolla for 700k. This thing will probably hold it's value better than most supercars, unless they supersede it.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
