Why lol they are an incredible car? Lambo aventador is same? Let's face it if u got 700k to spend it's not ur only car and ya probably buying it cos u can
Pretty sure LFA stands for looks Fkn awesome! Hahah
Leigh I'm gonna be at jdmst meet! Bring the fpv down!
I did but you left too early brah
and this proves why supercar manufacturers can charge what they do... with the exception of alex you are all looking at the badge before the car.
Bleh, I'm in favour of the LFA too, I listed reasons why the LFA will be irrelevant to most people here and why most would pick a Ferrari etc over one, number one being most people here don't have a spare 700k lying around nor have they "been and done" the other supercars. There are better performing supercars for the money, but no one's buying the LFA because they want to beat an R35 around the track with it.
Well, case in point, the last 3 pages have been about the LFA from a single sighting...if someone posted that they saw a 599 GTO it might have been talked about for 2-3 posts, if that. That's the uniquity that makes it worth buying IMO, regardless of how good it is. And it's not like you're getting a Corolla for 700k. This thing will probably hold it's value better than most supercars, unless they supersede it.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
