tripod
long exposure
and a trigger flash light
you can see in the 32R shot a ghostly blue figure on the far left
that would be the guy running around the car holding the trigger light next to so that the light floods in
Correct, was running around with a LED torch.
tripod
long exposure
awesome thanks.
Ive got a tripod, ive got a dslr, just need the torch and some skillz
Need to google some tutes
Lip and skirts and maybe another lip for more low
haha i parked on the point of the hill so i could get under the front bar easily. When on flat surface i imagine it will be quite low...probably too low to get up/down the driveway or in garage haha :/
cheers all for your critique. Will take it on board and let you know. Keep it coming (about the car that is :P)
The frontbar lip needs to be re-clear coated (unless i can fix it with a polish)
Recent one was a finale? o_O The double ep with them on the beach in the end? o_O
yep. show finished :\ it could of gone either way.. would of been nice to know the nice guy gets the girl :(
I'm sure in everyones head she has a flashback and remembers lol
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
