Why can't girls just get along?
6 years at working at the same place and there has always been a tensions/girls not get along/bitching between different sets of girls.
This also applies to girls that I'm friends with too.
All the work guys always get along and also the group of guys outside of work have never had a qualm.
Feel like I'm Dr Phil when girls are breaking down in my office.
Just sit their and listen but you can't touch! A manager has been sued before for trying to comfort a crying employee :/
thats seriously dumb!
human nature is to comfort someone when they are crying..
getting sued for it is pathetic!
Show him your roof :P
carbon fibre shtickerrrr!
Mirror finish :P
:thumbsup:
Hmmm well I have the a1rm sitting there atm so I might get them put in for the time being. Look into red stuff when I get a chance.
not a valid reason to chew through the DBA's.
QFM HPX's are like $80 a pair
Yup a manager got taken to court for comforting a staff member after she was crying. I.e. rubs on the back and a hug.
Case was dismissed in court, but having that mark against your name and months of stress wasn't good for the manager.
So I just sit back and hand them tissues :D
And yes bitches b crazy
And that there is one of the reasons people aren't as nice to each other anymore...you can get sued for being nice and errr...crims with bad intentions get off pretty easily :/
I remember some guy saying how he can't even look at or say hi to people's kids at the supermarket anymore, for fear of being thought of as a creep/pedophile...can relate to this. The times, they are a changin'.
That said, can't wait to get stuck into the ladies at my new job lol
Sexual harassment at a...legal firm? You got balls :P
i have my gtst going in for a rwc tomorrow morning - he keeps telling me my return flow fmic will need to come off..
just wondering if anyone knows where can i find documentation which shows its legal?
I've only been able to find it on the EPA information bulletin
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
