Plenty of RWD skylines around here that are far from stock with plenty of traction :thumbsup:
+1, huge power rwd can have traction if setup is spot on.
With Supra, I'm not looking for huge power, only BPU since it'll be easier for me to get a roady (I go through many cars).
this is SS8_Gohan's car right?
I've seen a few of these shot on the internet but not on here?
(if these photos are not meant to be seen, please tell me to delete/edit this post. just curious is all)
This crab is tougher than Kris' brother:
rofl
Grant why would you want massive power on a rwd car, it's no good if you can't put it down.
spoken like a true GTR elitist... ;) 325rwkw over here and lovin' it!
yes... and that's even Daniel himself in the car! ZOMG!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
