not really, do you go OH parking spot - stop - parking lights on?
Well it was a joke, but now that you mention it they do come in handy when I'm pulling in at night time and don't want to wake my dogs up. They are most likely there for others' awareness of your car though, and I'm sure the "parkers" name came from somewhere like parking in a dimly lit carpark during the day etc...
Pics of hot 10/10 eurochick that you just sighted or GTFO
Was at info day few weeks ago. Will get pictures when uni starts. Or mebe orientation.
more like a 9/10 because all the chicks there were ugly nerdy onesss. Engineering yo'!
The only problem I can see with that is there is no Parker. :S
Yeah, guess will just have to wire one in LOL!
Post pics!
was jokin brah.
i presume it stemms from how the euros leave the left hand side front and rear parker on so they dont get slammed into from snow/fog in poor visibility weather
i used mine for not hitting to house on the way in also lol
I learnt clutch bike when I was like 8 so cant be that hard :D same as car really find the sweet point and if you let it out slow enough you wont really need to give it any throttle, you wont get out of 2nd or 3rd anyway I have faith! gl with it all!
First day of two is just teaching you theory and how to ride a bike, along with bits about what they'll be testing on the second day. If you've ridden a bike before or confident you'll know how to, you'll get by with just the one day. Maybe tell them your situation on the day and they might give you a little extra guidance before they start everyone on the practice riding again - of which they do plenty. It takes like 10 minutes of riding to get a good hang of it. Just remember to slip the clutch plenty so you don't stall, you can get away with this on bikes as most have wet clutches. They have the idles turned up on the learner bikes, so as Leigh said you may not even need throttle to get moving.
lemme practice on your bikes :P
Mrs cats decided to have a play today so had to grab camera. First time they ever done it but funny shit.
haha cat matrix
Man there's gonna be like no skyline owners in the wasteland soon all motorbikes and shiz haha
coz we aint to keen on livin :laugh:
I might actually renew my membership and attend some meets once I get a bike
need to befriend some bikers asap for meets and shit, the only 2 kunts i knew with bikes no longer ride :sleep:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
