http://www.rhdjapan....e-kit-r32-15821
It has parker, i think its the ring around the main driving light.
Works out to be $310 AUS.
Then I assume +shipping... Hmm...
The CF intake / headlight replacement looks great!
Yeah had I left it in there I would have got my money back, probably even made some, but no one knew when we were gonna pull out of it so I cracked the shits / sold up and bought a Skyline haha.
Ah well it's only money can always make more!
fml, high pressure sprayed my car and paint flaked off the windscreen wipers which i painted not long ago ~_~
Might have to get them powdercoated or something...
Or learn to paint?
Just sprayed it with black spraycan paint, but its coming off. What i do wrong? :/
Use Etch Primer, not normal primer. I sprayed mine 3 years ago, used etch primer and black over the top. The only problem I can see with mine are some chips here and there probably from bugs or stones.
Funny thing rates, it's actually good they aren't dropping in terms of the economy yet the sharemarket dips on the news and people get disappointed they wont save $50~ a month... Forgetting the upshot they still have a job! And a relavtively healthy economy
What car you going to build up?
E39 528I
scored it off my uncle. schwartz black, with peanut butter interior. found a late model wreck with the black leather m sport interior.. so i guess ill pick that up instead of the R32 that pat posted >_<
Fk airbags I can see your whine thread when u get done an have to rip em out for roady
valid point good sir.
but damn bags would be nice and comfy as hell
Moh, by the time you're done spending money on it, you're gonna wish you offered that guy $20k for his 540...which you'd be infinitely better off with anyway. And you could actually own a cool car for once.
Unrelated, just took this for a road test...if the gearbox and clutch weren't completely f***ed it would have been a lovely drive. There's something about sitting in lounge chair seats, holding a shoelace thin steering wheel at 40...mph...in 4th gear with a V8 rumbling away. Must build one, one day.
E39 528I
I see, you gonna do a build thread in S/W?
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
