wouldn't the bigger brakes/grippier tires be more helpful then :P nah i said i might go for 600 coz i'm only occasional gona ride it for short distances, and cbf selling/buying
You'd think so but most bikes don't have ABS or traction control and most bike tyres are closer to slicks than wet tyres, therefore the wider the tyre the worse it actually makes you in the wet should you start to plane.
Just do the 250 mayne it's really not as bad as it sounds. I agree with dezz we won't lose sleep over it but sure wouldn't be nice to hear about you having a stack or anything. Gotta slow down these motorcycle statistics cause they are pretty scary ATM.
you be nice!
Leigh what kinda bike you got?
I got a suzuki gsx650f its like a gsxr but bit more upright seat positioning not a "super sport" just a "sport" bike.
Got fender eliminator now as well. (this one is non lams)
edit - found a pic with eliminator on:
only cost me 7k (2008 model) and its decent enough for how often i ride, they have about 10 less KW than a GSXR 600, but weighs a little more. I saved like 5KG taking off the ridiculous exhaust though. and just if you dont believe me here it is:
feels like you riding with a big dildo strapped to the side of the bike
Oh very nice Leigh! Lol that stock muffler looks massive! But yeah I like the "super sport" look better. Also dont wana spend 7k on a first bike :/ does look mint though!
Borci - as above, might aswell go for a naked ducati monster which is also LAMS spec
Birds - interesting
man how long you going for?!
go Germany in late September and ill meet up with you for Oktoberfest! :P
I went 2 years ago and I'm dieing to go back :D
the UK not so much.. =/
Agreed, was at Oktoberfest last September. One of the greatest experiences of my life. Had a German chick put her hands down my lederhosen in a random attempt to grab a handful of cock and balls, drank 9 liters of beer a day and ate a shitload of chicken. Win.
Pending Visa application (should be approved), will be there for hopefully 2 years as working holidays assuming I haven't ran out of money before then.
Was advised to head over Germany for oktoberfest... So yeah...
If I had my chance again I wouldn't have bothered with the working visa. Getting a job in the uk is almost impossible to start with, and when you do, you'll be lucky to be making $10 AUD an hour. Just giving you my own personal experience :) The economy in the UK is f**kED.
Actually... that's not completely true.
If you're planing then the width of your tyre won't make a difference.
Before you plane the contact patch difference is insignificant between something like a 160 to a 190 tyre. The main factors you should be thinking about is suspension, quality of tyre, pressures and of course the riding.
How wide is the rear tyre on them Leigh?
160
Yeah, I know the economy over there is f**ked, not looking to get rich over there, just want to explore the world while I've the chance...
So when most 250cc bikes come with a 130 at their widest? Significant difference between that and a 190...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
