lol I was just looking at some houses on realestate.com.au and a lot of the photos were taken with sun shining through the windows into the houses and no furniture, makes them look VERY hot to walk through, even today.
So damn cheap, someone buy it before I do something stupid:
http://www.carpoint.com.au/all-cars/private/details.aspx?R=12171585&__Qpb=1&Cr=10&__Ns=pCar_YearMade_Int32|1||pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|0&keywords=&__No=15&__N=834%201216%201246%201247%201252%201282%204294966879%204294729565%204294967079%20447&SearchAction=N&silo=1011&PriceTo=447&seot=1&__Nne=15&trecs=105&__sid=1355711DA55E
Mmmm M3's.
Last night saw Aaron's friend with the convertible E46 M3 convertible. 11 inch rims on 235 tyres :/
lol just saw that it's in QLD, looks like I won't be inspecting it on a whim. Still, anyone serious about buying one, that sounds pretty legit...cleanest I've seen for a while.
Disagree re: r32 plan
Harder and harder to find a r32 which hasn't gone down the cheap thrashed path. It is better to see a clean r32 than some cheap and nasty with power because that power is nothing spectacular so it's lose-lose.
My opinion would be to restore a r32 gtr but 4dr's provide a different view
Good luck with the rebuild, in 5-10years time when everyone has moved on to their family/boring cars you will have something which wasn't discarded because of the cheap thrash mentality.
Similar example; look at all the kingswoods being restored. Everyone looking for shells including the basic 6cyl models.
Tl;dr
Also, I just love r32s.
It's like when people do up those old rotors. They're shit. But in the end it's up to the owner.
I'm doing what I had planned for my first r32, only rwd and with a sun roof :)
Hey pat... Sunroof seal is integrated into the glass.. And they don't make them anymore. FML
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
