Would be good if the power FC was like the cappa flash tuners that way you can store a 98, e85, valet tune and not actually get pulled up on it by the cops because it still only flashes the factory ECU so you don't actually need anything plugged it
inb4 fords are gay, bikelineaustralia etc.
Since this thread is now run by crotch rocket enthusiasts.
Compared to cars, how expensive/cheaper are insurance on these things?
Generally cheaper, but what car and what bike are you comparing? My R1 is ~$800/year full comp, plenty of cars cheaper than that, plenty more expensive. Also plenty of bikes that cost ~$1400/year full comp and plenty that are ~$400/year. Plenty.
Cut up standard ECU, cover PFC in standard ECU housings, use a laptop to switch tunes!
I didn't want to cut up my ecu, so I just switched the covers on the pfc front to back, so the big apexi logo faces inwards. Put the Nissan sticker on the outside of the pfc, done.
Inb4 hwp
Birds, say your GTST and R1.
Both cost me ~$800/year full comp. Just pick a bike you like and do an online quote with a bike insurance company, that will give you the best idea. There are too many variables involved.
Inb4 hwp
Good idea, might try that.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
