on a long weekend with good weather it is
all the bikes and quick cars go thinking its going to be empty and an awesome run
but it would probably be full of slow std cars and cops trying to catch out hoons
Yeah not really expecting the roads to be empty.
So for anyone thats interested:
Meet Point: Macca's cnr of Springvale Road and Maroondah Hwy:
Time: 9:40 meet for 10am departure.
Destination: Via black spur, either going to the famous buxton burgers at the igloo or parmas up at Alexandra.
Intradasting....
May need to think of a plan B...
Yep tony, like you suggested, PLAN B!!
Still meet at the maccas on springvale rd and maroondah hwy for a 10am departure.
Pull out your map....
Take maroondah hwy down to lilydale. Turn off towards seville/ yarra junction/ warburton then head up to buxton/ alexander
Guys does anyone know much about meth kits? Methanol injection kits, connected to FMIC etc.
Need knowledge input if so.
You started your own firm or something brah? When are you hiring me?
Haha. It is in the pipeline actually, but looking at another 12 months minimum. :).
Very busy with other stuff atm.
do NOT connect it before the intercooler
only after and just before throttle body
ensure your ECU can detect if there is no meth and use alternate timing or adjust accordingly
i think it should be wired in via a pressure switch so it only comes on when boost exceeds a minimal level ie 6psi
so that it doesnt run meth when your on light cruise etc
also think it should be wired in like NOS, via the TPS, when TPS is 100% fire the meth solenoid
i purchased a kit but never got around to installing it.
http://www.aquamist.co.uk/vbulletin/showthread.php?t=2158
I have no idea about it. I have a meth kit, as it came as part of a tuning kit for my car. The ECU in my car does have a 'meth' map.
I might have the same kit or similar. But mine says something about mixing water and meth in the window washer bottle.
Too much confusion.
Anyone actually installed one or know of someone who has?
Also, where to get the right meth from?
Cheers.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
