laugh.gifdoes your gf agree?
Whether it's a Virago or a 1098 the riding speaks for itself, anyone can go well on a 250, including a cruiser :thumbsup:
She won't even sit on a Virago :closedeyes:
I have nothing against Viragos :3
Buy one of those repsol hondas they look best
:thumbsup: Recent Fireblade is highly rated. Repsol paint scheme is the bomb.
He also had a yellow hyasong 650r thingo actually looked pretty good and they're LAMs approved aparently
If you're looking for low down torque in a 600/650 then V's or singles are the way to go and since the Hyosung is L plater friendly it would be a pretty good compromise. Tooth down on the front even one up on the rear and you'll have great acceleration, remove the cat with a slip on (if it hasn't been done already) to improve it even more. May sound like a muck around but you can do this pretty cheaply on the Hyo's.
They usually come reasonably cheap as well and if you buy second hand depreciation will be minimal. I would highly recommend test riding a few bikes at some dealers as it can make or break a bike and you don't want to regret it... I think you'd enjoy the Hyosung!
yeah think i'm just gonna go for the 650 hyasong even though its indian/korean or whatever. whats the point of their 250 model when it looks exactly the same as the 650, same size and both LAMS approved :/
All this bike talk, just buy one already :thumbsup:
you just mad coz no one's talking about fords
Depending on how it rides and second hand availability (none in vic currently) I'm keen to get one of these in June when I come back from o/s. Extremely good value for money. Though if I end up streetfightering my Blade I won't bother.
Edited by JEPPE
650 and just get a tune or something to derestrict it.. cops / insurance wont know
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
