Not gonna spend thousands of dollars hiring exotics brah.
Have seen White lamboghini gallardo's as wedding cars...Twas nice.... :whistling:
how often do you get married do it right first time you're already spending ~$50k what's another couple g's...
put it under her parents' tab
Sorry no mansions brah.. Thankfully I got some options if i ever get married but wouldn't extend further than me..
I prefer low key weddings to over the top, classy but simple Fk having 300 people! Easier said than done though
I'm coming jerk
It's an Azn thing man...
Not same as Aussie weddings. You gotta invite 11ty.
Mine, should i find someone that can actually tolerate me, will be small 60-70 people. Rather have it like that with a place that does decent food rather than go en-masse and pay out the a$$ for 100+ people and decent food, or 100+ with crap/shit food etc.
Or go even smaller for the official wedding thing.
And a week later have a big afterparty type thing... Problem is just my close mates who i talk with every day, there is about 20 of them and their +1, plus a few others & SAU dignatires - so that's upwards of 80 people just on my side without even really thinking about it...
So ye, i think small-ish wedding and then hire somewhere a little fancy for some type of mega loooooose after party for the crew :D
All of the weddings in my family are the typical ridiculous wog weddings. I'm talking the cost of a house etc.
Don't think mine will be like that though, just can't justify it when with that money u could set yourself up for life.
Shattered all of my cousins are already married though, no more massive 6 course meal weddings on the horizon
Happy to be the driver when you have your wedding :D
Yup it's an Asian thing. A normal Asian wedding is about 400-500 people, with a 8-10 course meal with a bottle of Hennessey at each table.
Mine won't be going quite that far....
Yeah easy to see how an extravagant wedding can blow up in costs, if you have the money why not.
In saying that i'll be trying to minimise costs where possible whilst still trying to keep in somewhat respectable and decent.
same thing with funerals, at work yesterday box forest road in Fawkner was blocked off cause some many were trying to get into Fawkner cemetery
Funeral was right near where i was too, so again had to wait for it
lol f**k that. I went to a Coptic Orthodox wedding a couple of years ago, never again. If the half hour long prayer song with the same line repeated 200 times doesn't piss you off, standing for an hour and a half straight and breathing constant incense smoke bombs will.
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
