1333939875[/url]' post='6308324']
Tarneit/hoppers crossing/Werribee
I really recommend Platinum Motorcycles in Keilor East. It's just off the Western Ring Road so it's quite easy to get to.The guy who runs it, Louie, knows his stuff and is honest too. He's been working on bikes his whole life.http://www.platinummotorcycles.com.au/If you do go, tell him O'C says hello
not a great deal in the end
on the old falcons they had a dedicated cop cluster
that was used so it had digital speed readout and peak speed save / recall setting etc
nothing "important" and it's not a "cop chip" tune either
but they had to swap it out when they sold it as a normal car
ie a pain in the ass, but back in the old days
these days its just a toggle setting
you can turn police mode on and off on any ba cluster via the ODB port
in fact, you can change the whole car, including remapping via ODB port
on the BA
when you enable police mode
the cluster simply shows digital speed in km/h (and speedo dial) and has a top score / speed recall feature
normal BA cluster has like fuel economy on avg fuel etc
this is all disabled in the police mode to show you digital speed read out (and speedo dial)
theres also some other trick to make all the lights go off in the car
like the interior ones again, nothing special
R33 GTR's already look good on it own, maybe the Nismo 400R kit, but I quite like the Veilside kit. Looks Tuff!
tumblr_lnvvueuSsj1qcj56b.png?1318394475
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
