Billy speaks the truth. Lol.
Its a really good budget car. So easy to park too! Haha.
Oh, is the one he linked you and EFI one? Generally the EFI's are a lot better.
No idea, all it says relating to the engine is v-tec
I'll send u the link when I get home
lol if he is referring to the EG Civic vti-r (with vtec) its a peice of shit
Single overhead over-rated with "vtec"
Friend had one, not worth the money and too many people are tryhards with them. Plus it isnt real vtec. My friends have integra type-r's and s2000's and they are true vtec. Not an EG vtir.
Tell him to save his money and buy a regular EG Civic GLI
The vtir model is better than gli, also have better features. They are selling for roughly the same price. I know I'd rather the Vtec motor than the carby motor.
I don't think his brother is buying the car for e-reps, it's just a daily
Its actually just a VTI (not vtir, that's for EK's). SOHC VTEC. Which means its EFI. Do not buy a carby.
FYI, Sohc vtec are amazing to turbo. A lot easier than the Dohc vtec's (B16/18/20 F20C).
Yes I agree (@Rekin) DOHC > SOHC Vtec, but dude just wants a car (And by the sounds of it, can't be a powerful one by what dezz says), and the VTI would be a lot more reliable than an old carby. Its worth the money just for a car. Not worth the money to mod them.
And yes what billy said is true, the VTI was a more luxurious version compared to the GL/GLI.
http://www.gumtree.com.au/s-ad/hillside-3037/cars/1994-honda-civic-hatchback/1001227153
That's the one he's sent me, so base all your feedback on that one lol
He just needs something cheapish and reliable, but obviously being young he doesn't wanna drive a complete heap of shit like his brother :cool:
GLi's arent carby motor. The GL's are i believe.
People are charging vtec money for the vtir, when they not worth it. Not to mention thrashed and paraded around as the poster boy of vtec yo.
http://www.gumtree.c...back/1001227153
lol fart cannon, steelies and 200,000km. Sounds like its had an easy life...
Guy probably used a can of tyre shine on each wheel. And on the steelies too!
Tbh, if the engine feels healthy, engine mounts good, bushes and brakes and all the mumbo jumbo are good. I'd go for it.
My civic probably had the easiest life ever before I had it. Everything is so perfect. Haha
Billy has an ek? Awesomeeee. i'm not alone xD
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
