When wheels coming Leigh?
Does anyone else get the old skin on iPhone if u click back a page button?
They're in the post at the moment, but need to get them powder coated or painted black.. what's best method?
and 75% death to night riding
Lol yeh I had to take mine off tonight riding to the the sau vic meeting with birds
they look good in daytime though.
They just called monthly meet ups now, we scrapped the formal crap of yesteryear. It's more about the cars and casual meeting spots now, so there'll be more like it. I'm digging it.
yeah i saw the note when i was looking at the htc one x - and thought 'f**k thats huge' and considering the one x is already bigger than the iphone using the galaxy note would almost be like using a tablet!
i took a pic for you to see difference between iphone 4 and one x - not the best lighting but meh it will let you see size difference..
God damn, that is a huge phone!
Galaxy SIII out 3rd May :)
Intradasting....
Nah pretty sure it doesn't. They're what the rear stands use to jack the bike up though yeah
I had kaneg stands
http://www.kaneg.com.au/products/Rear-Stand-plus-Free-Spools-%252d-Silver-%252d-Motorcycle%2C-Motorbike%2C-racing-paddock-stand-%252d-suits-most-sports-bikes.html
95 with free shipping, or 175 for front and rear
oh damn you!
its just under 'settings / android' and named 'power control'
not sure if that helps >,<
hahaaha :D
phone is fkn awesome. loving it. so much faster than the failphone
already considered that but dont trust myself with paint lol
picked up a tinted visor + rear stand just coz they look cool...
give it a shot. you'd be surprised what a little care can do.
+1 for powdercoating. I had some scratched up, dirty old S15 rims powdercoated...they looked like brand new factory wheels after powdercoating. I could only fault one wheel up close and that was most likely because of the condition of them beforehand.
pushed the car up the road to get it up on a hoist so my rwc guy can check the sussy and make sure everythings good.
hes rekons its a gem for an r32, and the unicorn of ex drift cars lmfao
only fault is the rail jacking points are pushed in a little too much so looks like were pulling them out and getting new ones put in.
FML.
Interesting. I have heard the opposite. Powdercoating is cheaper so you'd think it'd be not as good
Nup I've also heard stronger, makes sense as its a different chemical bond compared to just a layer of paint on top
FML.
Can't just pull them straight and be done with it?
FML.
so are everonye's.... i wouldn't bother
yeah thats what we've just decided to do.
i wonder where pat lives......
Moh, quit while you're only slightly behind.
after ive blown all of my money on it? f**k no.
i want to own the very best r32 sedan, the best there ever was, to comeplete is is my real test, to own it is my cause.
R32 SEDAN!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
