lol your f**ked. man the chick in the avatar is pretty bangin' though
Tony's a broad minded person.
I got other pics just in case lol
Jump on and reply brahs
I want to make them all jelly and rustle their jimmies
you should tell em you want to meet up, and then sticky tape a forever alone thing to the wall where you tell em to meet you. and take a photo of them with the forever alone.
i know its been done
lol thats harsh brah
Post up you want to help and ill accept make the other members jelly
She looks Asian in the before photos and the make up is an awesome transition, but she does have the right kind of features to pull it off from the start.
Can always count on you for jimmy rustling...
Just a messages of 'hey'.
Nothing saucy or guys asking for nudez yet.
Haven't replied yet
I'll post em up if they get saucy
Play hard to get or keep it subtle like a real girl to string along. I guess what I'm saying here is, be yourself muhahaha. You go in head first / ultra keen and obvious troll is obvious.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
