Reading up on the engine that will be going into the 86/BRZ. Subaru are putting a twin scroll turbo version of the engine into their 2012 Legacy GT. Potentially easy transplant into the 86/BRZ? 221kw and 400nm...
Yeh the ft86 run a compression of 12.5-1. Good luck to people who want to turbocharge the thing without either e85 or a decomp plate. They should have put the Subie version in all of them
It wouldn't surprise me if the second release of the 86/BRZ came with that turbo engine as an option anyway - it would be the logical choice if they were to release an "R" model - just a question of whether it fits into their marketing plan or not.
I think it all depends on the market that buys it I think. From a survey that merc are basing their upcoming range on is kids don't want fast car they are trying to get into classy things.. So mercs new range is aimed at kids, especially the price range..
Toyota wont put turbo charges motors in unless they're diesel because I reckon to have that option it's going to be f**king expensive with too many competitors
Well the Merc survey kind of contradicts the existence of the 86, which is as far removed from a Benz as you can get...but also a new car aimed at young people. The closest competitor I can think of in the expected price range of the 86 is the Golf GTI or MX5 and even then, they are completely different cars. So assuming the 86 succeeds at it's own target market, there may be room for a turbo model afterall.
That being said, I'd expect a turbo version to add at least 8-10 grand to the pricetag of the 86, with upgraded brakes and wheels etc., which would push it into Golf R32 / STi / Evo territory?
Well they obviously aren't aimed at the same market then. A turbo model would suit a mid 20's age group. If they are putting it up against a hairdressers car then they will definitely not turbo it. I guess they'll have to wait and see what market is buying them.
Nunawadding toyota have already asked a certain person to create the official optioned turbo kit for them, and kind of laughed when we found out the compression of em
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
