Vegiebar on Brunswick st?
pfft, that joint was flavour of the month back in the 90's
might have been hipster acceptable for the duration of 3:32pm-4:14pm on Friday 17th March 2012, but even that was strictly for kitsch value.
fact is that you can never know where the hipsters will pop up as it is guaranteed to be somewere "you would have heard of" In fact the only thing that is certain is that they will serve melbourne bitter.
so get this for fucking stupidity...
I just got a call from keysborough golf club telling me that my old man cramped over in pain and then fell unconscious with his eyes open.
ambulance was called, he has now woken up and is refusing to go to hospital. he has instead decided to finish his round of golf. - despite the face he may have just had a heart attack.
i'm in the city, so there is no way i can get there in time, so my mother is en route as we speak.
I have called the golf club to get them to call the nurse on call and make him speak to them, who knows if he will though
also he has turned his phone off
Something my dad would do.
Hopes he's ok bro! Just leave nab they won't mind dude
he's at home now, mum is on her way over. there's no point leaving work man, i just spoke to him and he's refusing to go to the docs. mum might be able to convince him but i doubt it.
i'm self managed, so i can leave whenever, it's just that there is no point as it will take me a solid 90mins to get there and mum will be there sooner
Yeh this is true. Your mum should be able to talking him into it.. Women are good at that shot
Hate to say it being your dad and all Ham, but Darwin was onto something. When there are people dying of terminal illnesses and doing everything they can to stay alive, people refusing simple precautions for things like this are a bit of a pet peeve.
Age and stubbornness are heavily correlated.
dont't worry man... i totally agree :/
On topic, noticing more and more my dad taking after his old man (not with us anymore) in terms of senility and stubbornness...to the point where, like my grandfather, I can't reason with him on a lot of things. It's scary to think that I'm headed for that too...I'm already pretty senile and stubborn :/
The look of dismissal on his face after I suggested he get his Cobra polished and waxed because the paint would look infinitely better ("It already looks good!")...oh and he put one of those $15 eBay resistor things into his old Cobra, then tried to tell me how his economy and power had improved significantly -_-
you'd dad's not senile dude, he's just stupid
:P
Sounds like hipster talk to me
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
