then why didnt your say it looks like a GTB4 instead of saying it looks like a GTR with 2 extra doors..
technically its neither of them so by saying it looks like a GTR isnt like saying im building a GTB4.
oh f**k some good fishing going on in here.
because no one knows what a GTB4 is
because you keep taking pissy little cheap shots, and im just going to feed the childish troll.
my jimmies have not been rustled.
i have a feeling your jimmies have indeed been russled, especially when you had a little tantrum earlier..
lol f**k up chocolate.
when are we all catching up? seems to be no events for a while :/
At the end of the day for an Individual Tax Return, all an accountant is doing is inputting what your already entitled to.
The fee paid should not be correlated to the tax refund received.
Unless the Accountant has devised some tax planning measure that was used to generate that refund.
i.e. the Same work required for Joe and Jane. Joe needs to pay $500 in tax and Jane gets a refund of $500. They both should be charged the same amount for the work that has been done.
Note I'm only referring to simple Individual Tax Returns
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
