blend in with normal muslims to avoid persecution
how times change
I have a feeling my default wins of best r32 gtst will end
fyp
Hamish going to try the feed me option at Chin Chin tomorrow night as you suggested
Hopefully its the goods
should be !
Haha, with the amount of people selling their skylines for golfs there is still a chance.
Once you sell yours, who would be the longest owner remaining?
Hrmm I've had mine since early 2006. So that's about 6 years and abit
Mine was aug 2006 I think. The surviving battlers.
An r34 back then was a lot. Moneybags
Yes it was!
On 3 x more monies now yet I had alot more financial freedom back then.
Such is the life when you are single and living with parents
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
