At apple peel car wash and there is a ferarri, lambo, multiple 911s, I feel so poor right now lol
I would recommend never visiting the UK or Europe then - too depressing. For my car I could do direct swapsies with an 07 Vantage, so cheap! So unfair :(
Indeed, especially around Chelsea and Park Lane in London... Saw 3x 458 italia in space of 5 minutes! Followed by Audi r8, Ferrari California, some gaillardia and too many range rovers!
My bike idles at 900 lol, less than my Skyline.
Nope been working 6 days a week since november
Went for a kick earlier today, haven't kicked for 9 months...needless to say I was terrible. CBF with the injuries this year.
lol i stayed in Mayfair in London and the amount of epic cars seen. Saw a Bugatti Veyron driving around.
"Mayfair has become an attractive location away from the City of London for private banks, hedge funds and wealth managers" - explains it lol
hmmm maybe i should get into the banking industry.... lol
Thinking the same when I wandered around Park Lane/Mayfair...
Me go to university? Cbf, I've got no attention span to go to uni, haha.
You guys should try staying in Old Kent and Whitechapel.
only the dark blue properties for me :P
Funnily enough, stayed in a hotel on Mayfair. Asked about any nightclubs around the area, the hotel called the club and put my name on the guest list, walked in like a boss. Apparently some celebrity / vip hotspot.
Handy tip for the travelers out there. Ask the concierge for entries.
Shout out to Hamish.
Food at Chin Chin was awesome, flavours and textures were great. 'Feed me' option my stomach was about to burst. Dessert was the highlight of the night, think it was a coconut ice-cream with honeycomb.
cop choppers been circling overhead for a good 15-20 min now
must be a drug bust down the road again >_>
croydon lol
Seems to be a common occurence now (I'm in Bayswayer North.) I live with locked doors lol
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
