Bluefire grill waterfront docklands
Not bad
All you can eat when you're not even hungry = shame
Soccer + motogp on tv = win
lol <3 Bluefire, they hassle you non-stop until you flip that card over. Go there on a Tuesday, I think it's half price then.
My friend put a multi-bet on the Italy Croatia match...Pirlo to score the first goal and the game to finish in a draw...$5 x 90-1 lucky f**k!
Shout out to Hamish.
Food at Chin Chin was awesome, flavours and textures were great. 'Feed me' option my stomach was about to burst. Dessert was the highlight of the night, think it was a coconut ice-cream with honeycomb.
chin chin means penis in some language.
Any of you ever had the chance to try Warthog? Take the tenderness and juiciness of the best fillet steak you've had and times by 10. Omfg soooooo delicious. I've actually lost my appetite for other red meats after that. Had it last weekend in Zimbabwe and not sure if anyone imports it but I'm gonna find out! Bonus was the three course meal for my bro and I only cost $75 best!
Nismo engine/gearbox mounts or Factory mounts?
The stiffer Nismo mounts create more vibration through the body of the car, not sure if its something i'd like in the car... More vibrations = more rattles
Anyone running Nismo mounts?
I was very unimpressed but then my first try of brazilan BBQ was in rio, sooo much better!
nah, it took 3 years of 300rwkw on a 200,000 km motor before i managed to snap my mounts....
replaced them with new oem ones when the new engine went in
bluefire was good value
~$50 p/p for the all you can eat menu including drinks (on a friday)
just under $60 with desserts
was annoying, they should just put the meat on the table and go away instead of coming over every 2 minutes "would you like some more?" ofcourse i want some fkn more wtf do you think!
lol yeah i lost $100 to my brother and $50 to a mate over that game :/
btw does your bike have a display that tells you what gear you're in?
but you forget, these engine mounts have to live with the power of the mighty rb20 :P
Although the factory engine mounts cost more than the Nismo mounts, ill get the factory ones for comfort....
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
