^LOL. Also waiting for delivery of said pics.
Varex ftw, can transfer it from car to car anyway so it's not a huge waste of money. Saved my ass a few times :)
A long term investment you say? That may be enough to convince myself to get one hehehe :P.
Edited by kaitoukid
If you google 'Digital Gear Indicator' there's plenty available online. They can price up to ~$200 legit so I'd recommend something cheaper on eBay, $20 and hopefully it works lol. Or you can get to know your revs. If you know what your bike does in top gear at 100km/h then you can translate it to lower speeds and gears.
Did you like the meat though? Everyone else here seems to be ragging about it, I found it to be quite good and I even ate...get this...some medium rare beef...dun dun dun.
Nah no gear indicator. You can get aftermarket ones but cbf. Only time I'd find it useful is on the freeway, for knowing you're in top gear, but you can tell from the RPM once you're used to a bike. The rest of the time it's irrelevant what gear you're in, keep it in the powerband BABY
you using my babies now?
i have no complaints about the meat i thought it was good aswell but i'm no masterchef judge like everyone else here seems to be lol
as for the gear display i think it would make finding neutral alot easier lol
that along with a fuel gauge should come standard with every bike :/
i'll look em up thanks
I don't have gear display or fuel gauge lol. It's one of those things I wouldn't complain about having, but not a determinant in getting a bike cause it's pretty easy to live without them. There's more important info on my screen like my stopwatch :P
How u know to fill up with no fuel gauge? Mine is a life saver but I hate getting petrol so I wait till less than 10kms to empty to make my move
Lol
+1111111111111
fkn drainer filling petrol
Lol
Bike switches to it's reserve tank and puts a low fuel light on. My bike also flashes "F-trip" on the LCD screen and starts counting up km like a trip meter - you get to about 40-45km before you completely run out.
Some older bikes made you manually switch to the reserve tank when the engine started chugging lol.
+1111111111111
Try walking to the servo when you run out of petrol one day lol.
What's the point of a reserve is it's automatic? why not just put on a low fuel light
I ran out of fuel once, the red light didn't work :-/ Pushed it across an intersection to the BP
You only have reserve on bikes with carburetors (which is a physical switch), fuel injected bikes don't have a seperate tanks so it's a low fuel indicator. It's known as reserve because ye old days terminology carried over.
I usually find out how many k's I get to a tank and then reset my trip meter each time I refuel which then becomes my fuel gauge. Or you could just look in the tank.
Edited by JEPPE
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
