I did engineering for almost 4 years. Eventhough It had no benefit for me at all I still wouldn't call it a waste of time. It's just another experience in life.
can't stand people who say "life is too short etc" just another excuse for them to be lazy f**ks.
Each to their own.
Bike styling is superseded more often and drastically than cars which could be why they seem older sooner. Mechanically they don't change a huge amount in terms of reliability. Just get the bike checked out before you buy, there are companies that do this.
Were you thinking of checking out that yellow 749 Rimon or just browsing?
Just browsing for now
Wanna put mine up for sale soon
definetly wouldve gone to uni if it was more like american college.
this song makes me jelly of america ahah
edit: lame censored version ruins flow. uncensored is way better
Edited by drunkn snail
Farrkkk...
Are you one of those who did English, Maths Methods, Specialist Maths, Physics & Chemistry?
Ric now officially the smartest guy on Wastelands
That's like the standard year 12 for engineers
mine was English, Maths Methods, Specialist Maths, Chemistry, Accounting, Comp Sci
fun
Indeed, mine was English, Methods, Specialist, Uni math, Physics, Japanese.
Standard asian 5 with some tweaks (was not a fan of chemistry...). Ah, a simpler time when I was more successful in studies LOL. Now not shur if dumber/everyone else smarter/shit is harder/too lazy etc. That meme comic a few pages back nailed it xD!
I just spent an hour in SCA... only walked out with like some car wash and a cheap chamois LOL sigh...
Oh and Nick...anyone who works in a family business knows it ain't 9-5/7, that's just what the payslip says lol. Even outside the unpaid overtime, the future of the business and day to day running sits at the back of your mind, day and night!
thisssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss
Yeah I know, just for people that didn't
heh, family businesses.
Y larf 4?
Naw poor Birds didn't get his due credit :P
Wind is intense today! Walked to RMIT and back and just about got blown over 10 times... shouldn't have lost all that weight :/ Should be fun for you on the bike tonight Birds!
he will now :P
Yeah I know you knew, was giving you my support :)
THANKS BRAHHHH!!!! :wub:
edit: I had nfi what was going on until now :P
Yeah I'd hate that too
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
