Hangin to suss it out tomorrow billy!
Gotta say sick of hearing about boat people.. Yeh I'm heartless rah rah send em back should be looking after our own and people who are going about things the right way
Obviously not saying let them die at sea just that put em on a plane and send em home once they arrive
Picked up the 86 today! I'm so Happy. Might be going to the JDMST meet on Saturday if anyone wants to check it out
Grats on taking the plunge...at least one of us had the guts to lol. How is it for head height? How tall are you? Engine give adequate power? Might come past on sat for a look.
looks really good. and i see an intercooler.
That pic is of the Scion Fr-s, which we won't get. Though I wonder it would be easy to add a body kit for a similar look.
Because that looks the goods. Here are the original pics:
dat asssss...
whoever shopped it did a pretty good job
I thought u already bought evo6 wheels
fell asleep and missed the auction lol
Momo, buy my wheels, lots for sale, need money to get to Japan
send another attack helicopter and ill consider it <3
pretty sure that's a concept - frs looks the same as the 86 but with different badges
Correcto...though the FRS does have black tail lights, I'm fairly certain, which are sex.
New cars won't come out with black lights I don't reckon. Chrome tail lights is kind of the style with cars that have good fuel efficiency, and carbon neutral, which probably is the explanation behind it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
