Compounds are sick, but it's almost too easy; I like the traditional feel of the recurve. Can always get both?
No compromise! Ride my bike sometime; you'll see what I don't wanna give up haha.
Tax return > custom leather two piece suit > Phillip Island!
haha alright we can switch around next time :P
always feels weird switching from road / motard
no
i want the medics to be impressed as they collect my body parts
Bahahahaha, I've got to hand it to you, I may not agree with everything you say but you sure do sick to your word. Respect enough, but srsly, I hope that never happens to you.
Daytona sounded good from what I heard..
Also I liked your pace through the hills.. quick and fun but not silly (considering we don't know the turns) I always prefer following for some reason.. the DRZ kept up fine just some of the higher speed straights (120+) Adam was gone haha
Too bad we didn't get a good run down Burwood highway end
Thanks dude that's a pretty rad compliment! I tend to be hyper aware of my riding when I'm around others so I'm glad it suited. Spending the day buzzing around the peninsula had worn me out so by the time I got to you guys I was happy to cruise. Muscles are sore today!
Daytona sounds ok, the Micron pipe isn't too bad but I think the high pitched note triples produce is either a love or hate situation... And I'm leaning towards the hate :( apart from that it's a nicely balanced bike just a little underpowered. I wonder if a full system would fix that... Hmmmm :)
Might be a goer then. That's my biggest issue with stiff coils...accelerating up a hill / around a corner and losing the rear end over a friggen bump :/
greddy type s - do it
Insuring anything is easy, putting a claim through is a different story.
not at all, he's with shannons...
hell I put a claim through for an acco between two cars that were both insured with shannons that had a love tap in the Sandown raceway carpark and they didn't even question us.
honestly it wasn't from the trackday and it DID happen in the carpark, but I did expect them to at least pressure us a little bit.
basically call was:
hi shannons i are accident
hi r33 how accident happen?
i in sandown raceway carpark, someone back into me
icic, where you want fix?
i are micolour customer
ok npbs, micolour are trusted repairer
kthnkbye
i got mine through j imports...
there is a set in autobarn chadstone that hasn't moved for like 3 years
IMHO call chaz and tell him i told you to buy them
tell him you have (insert amount you are prepared to pay) and see what he says.
he wont want to let them go cheap cos he will have to make a loss, but end of the day they are not moving
just check they are for a 33 first
basically call was:
kthnkbye
yeah the dude was pretty chill on the phone.
explained its a GTB4 rep and shit.
premiums 1990, insured for 9k (thats without seeing pics of it etc, they want to see it finished and the dude goes theyll insure it for more)
Whoh fark that. 3rd party fire / theft covers up to $10k and costs $600pa...
Didn't you buy your 32 for $2000?
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
