What speed is say 4,000 rpm? Do you have an old graph of the stock turbo?
Probably 120kph'ish dunno why he does it in speed and not rpm.. :s
I have one but it's from dr drift. Who basically fkd the tune.
The last one cihan did is on his website I'll get it later
You said you were limited by injectors yeah? What is the estimated figure if no restriction on 98 octane?
No idea. Planning on running it at 25psi later down the track. The turbo goes out of efficiency only after that so it should crack the 300 on pump no worries. People are doing that with a .63 with a .82 it can only be less restricted
The drop in power up top is a spark issue. Looks like I'll be needing splitfires for anymore power, and cihan(tuner) reckons there's a bit more in it for 98, plus quite abit for e85
Not bad, midrange is a bit lacking but that's to be expected with 2L and .82 rear. Ethanol will help that a bit
Yeh so it shows. But it's picks up revs too quickly to really notice while driving. Ethanol should make of all the better!
Pancakes + butter + maple syrup + ice cream + chocolate fudge + wafers + almonds. Feeling kind of fat...PP strikes again.
Unrelated, did not know there were 9000 bodies buried under Queen Vic market.
sandra sully with the late news there buddy.
thats why the support beams arent secured in the ground, but instead on massive cement blocks.
the construction workers were sick of diggin up dead peepz skull n shiiiet... ANNNND why they do haunted night tours :yes:
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
