exactly, but not one of you can do anything about it? lol i find it funny that the only person that can is the one that says "I dont get paid for it so you cant expect me to do it as pleased" why doesnt he give the authority to one or two of the other execs who will and "have the time"?
/end rant
Edited by Sunkist
Ask Richo if there is a spare role, not sure if there is at the moment. But I may be unaware
As for the above comment I agree, already been down that path brah :/
There's alot of stuff that goes on behind the forums re issues and complications that are always discussed that the general forum users are not always aware of
Edited by blah_blah
Not a lot we can do about it, SAU Vic is a seperate entity to SAU; Ash being in charge of the latter and he has never wanted to delegate forum power to SAU Vic execs, so you'll have to be patient :)
Lol I don't care about being an exec I was annoying you.
But passionate about people paying for shit to support the club, and not have a prompt return.
When u go to Coles to get eggs you don't pay for them and have to wait 10 days for them to become available.
There should seriously be someone else handling all of that if that one person isn't enough to keep up. It's probably half of the reason why people don't bother becoming a member
im considering not renewing my membership.
we need more events. clubs dying.
Not the club the cars dying not many fks are given rembering it's a 15-20+ year old car in most cases
How many cars of that age have big clubs/memberships
The Club has no say in how the forums are operated or managed. The forums allow each club a unique area for their club members, however forum rules still apply within those areas and ultimately the forums still control those areas, though the clubs do have some moderation control as well.
We make requests, just like any other forum member can. That is as far as we can go.
I do hope that the situation changes for the forums in the near future to improve the situation. As the last 2-3 months have not been great forum compatibility wise.
Spoken like a President lol
thats exactly right, but the fact that the moderators wont expand their teams within the Club exec's is pretty poor form, its nothing against the club itself, but more the moderators running the show.
its a simple task, I'm sure that it doesnt have to go before Julia Gillard to grant moderator access to someone such as yourself, it probably doesnt need to go before anyone for that matter, and its a selfish act for the moderators to restrict members access to something they've payed for because they can't be bothered doing it.
There are plenty of people trustworthy enough in the commitee team ie, yourself toby Dan etc, that wouldn't walk around like Mad082 waving their banstick around to justify their ego.
nothing against the vic club, if it was I wouldntve renewed.
/SAUnion
Edited by Sunkist
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
