Ahhh welcome to the wasteland. Have to have another cruise soon when the weather is a bit more promising.
He was killed in the truck or by a truck?
Yeah not great weather for cruising, we should do Kinglake and surrounds sometime?
He was driving a truck and left the road.
Some good routes up there, I'd be up for it. However, of recent it's a known hotspot for the popo / yellow sticker people...so the more modified of us might not be so keen. Will have a chat with Tony and see what we can do.
Sad shit that, that you can be minding your own business without a worry in the world and in the next 10 seconds you're dead through no actions of your own.
These are the thoughts that bikelinesaustralia put up with everytime we ride.
That's what I said! Truck driver probably won't get anything either
So sad
Current brake set up is F242/Rdrums right. Should me buy brakes from vtec that are F262/R239 that'll be $500. Or wait out for Type R F282/R262 that will be 5lug (means have to buy new wheels/tyres) and would cost $1k for the brakes alone.
I wont be tracking this thing as of yet, but it'll be nice to get rid of the drums. Do some deca's ect.
Leaning towards the F262/R239 4x100. Which I can go pick up right nao.
take a lesson from all the old skyline owners here. Dont spend money on parts you dont need, Get out on the track/deca first and then decide what needs to be done.
Everyone falls into the trap of building track cars for a hypothetical track day sometime in the future.
Get out there now, find the limits with current setup, then replace to push the limit further.
So sad
if it was human error / fatigue i say put him away for 40 years cos that shits f**ked - shouldn't be able to wipe someone out and get away with it
This man, he knows.
Speaking of, Yoshi rearsets installed...darkness is spreading!
Can't wait for Pazzos to arrive :D
is it so hard to step 2 feet back then take the pic? :angry:
looks good. cover that bottle with something black so it's hidden
epic decision i made not to take out the bike today coz as soon as i got out of the driveway in the hilux it started hailing like a mafkr
Yup have a few guys asking when the next one is.
Will have to do one again, unfortunately got Winton & Haunted Hills coming up over the next 2 months, so just getting my car prepped for that.
But yes $2 Midnight Cheese and bacon rolls.
Haha I knew you'd say that...almost done.
Good call on the weather...deceiving shit.
can't wait til i am in le position in which i can afford both my car and a bike!
meanwhile in my current situation... coilpacks so expensive fffuu :P
You never win, when you are in le position there will always be more expensive things to get.
My r32 was better off when I was a student on casual wages. Now its all about budgeting & being serious with money :(
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
