was good.
weather, cars, no issues(while I was there)
saw a supercharged 350z that was totalled the day before.
suprised at scott in the wagon pretty much smashing everyone else in his class lol
no idea.. was a yellow track edition.
guy came to pick it up and was still pretty devo..
looked like his daily too with the vic number plates and stock wheels. thing was completely totalled though the only thing not damaged was the passanger door and the roof - the car wouldnt even sit straight.. was such a waste!
Expendables 2 good shit but few fails
1. No Jackie Chan
2. JCVD not on the good side
3. Master badie not being the one and only Bolo Yeung
In other news, not bad weather. Pointless since you know by the time you get home you'll be too dead to go for a ride
nice.. goes to show you can still do some good times with a whale
what car was the 1:52?
motor mag did a 1:53 with a ford f6.. faster than what they did with evo 10 around PI which i find hard to believe
edit: better post some proof before I get flamed /fordsareshit:
https://docs.google....ZQNnlHS1E#gid=0
1. No Jackie Chan
Jackie chan never kills people in his movies. Wouldn't be a good fit for him haha
1. No Jackie Chan
If I go solo, I'm doin a song with Bolo
A big Chinese nigga, screamin "Kuniva yo yo"
Seeing it tomorrow night, pumped
why? freezing?
- VLINGO - it doesn't work and you can not turn it off unless you root the phone.
- freezing - more and more often
- touch screen - not working in some areas which read false touches
- kies software - soooooooooooooooooooooooooooooooooooooooo shit and crashes
- battery life now 1/2 day
and the main prob...
- the button... the only real button is now broken and registers a double tap when you press it once... this turns VLINGO on and the phone (EVEN WHEN VLINGO SWITCHED OFF AND THE PHONE IS ON SILENT) will loudly annouce:
"WHAT WOULD YOU LIKE TO DO?"
1. No Jackie Chan
It's very entertaining, agreed missing Chan but has a LOT of others in it. LOLed when chuck norris shows up..
Phillip Island it quite a fast track though
Woah thanks for the link! That's awesome
I was coincedently looking through all my old motor mags last weekend for track times done at Winton!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
