Hurry up and put the mods back on Pat!
haha in time.... Received the new pins for my nistune board. (snapped them when removing the board) Need to solder them on.
Also need to send off injectors to be cleaned and new o-rings
Then we are good to go!
My treadwear is 360. Dat unlimited rubber. 10kkms and still can't see no wear or signs of camber wear. Bahahahahaha
what tyres?
dat return flow
Means ill have to lose my front auto spoiler and put airbox back on :/
and hopefully it doesnt hit the foglights either :sick:
not sure if pro's greater than cons...
Buy it, sif worry about auto spoiler and fog lights
just use rubber lip for front lip
And then see you at Haunted Hills? :P
Falken ze912's or something. Not that good of a tyre. Good enough for 1.6l :P
They stretch real nice too. Really nice.
better than my Toyo's?
I might try stretch a 205 on a 9 when 17's are ready :P LOL
what, scared of a little blood?
no srsly, what made you change your mind?
nein. I actually looked that stuff. It's the lifestyle it requires of you and the sacrifices you need to make. Also medical admin purple can gagf
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
